Missing my obd II connection please help!
I'm starting to do my harness as it is getting close to starting my swap.
In my plethora of ignorance I realized that I didn't get my obdII connection with the harness so I'm a little stuck before I even get started. Which wires get connected to which wires when I'm fitting my new obdII connector? Also, can I use ANY chevy obd connector or does it have to be vehicle specific?
Guys, I'm really really stuck and dead in the water here. Please help!
That's MISTER MODERATOR
I would suggest you have a look at these and I'm sure you'll find what you're looking for:
http://www.bing.com/search?q=obdii+p...82c1992d42309d
The wire for your odb2 should be number 58 on the blue connector to your PCM, it should be a dark green wire. Then all you need is 12v and a ground. You can use any odb2 plug, I got mine off of ebay, make sure you get the "male" end, the one I got came with had pigtails that I had to switch around. Use this to wire it up. http://www.mstewart.net/miata/wiring/OBD-II_Pinout.jpg
