How to figure out boost with pulley size?
LS1Tech Sponsor
How much boost the blower can produce depends on many variables.
* Cubic inch. The larger the engine the less boost it will make with a supercharger.
* Headers and exhaust. A better flowing system will produce less boost, requires a smaller pulley to regain the loss in boost. Ultimately though, more power will be gained.
* Camshaft and heads. A camshaft with some overlap will leak out some boost through the valves. Better flowing heads react a lot like a better flowing exhaust system.
* Altitude. Elevation plays a big part in how much boost is produced. Those people living in the higher elevations have to spin the blower harder to see boost.
* Condition of engine. An engine with real good sealing rings will ultimately produce more boost than one with worn rings.
* Rpm. An engine that is spun up higher in the rpm range will normally produce more boost.
* Head unit used. Blower pulley sizing is affected by which head unit is being used.
Bob
Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Boost #'s will be differant with every engine depending on it's efficiency. Same blower and same pulley combo might make 15#'s of boost on a 347ci put it on a 408ci and you might see 10#'s. There is a math formula to figure out blower RPM and CFM getting pushed in to the motor.
What Blower are you referring to ?
Thanks guys I can post info on the motor like cam size etc if that will help.
The blower is an F1R
Motor is 430 lsx iron block, afr235 heads, forged bottom end, -28cc pistons (9:1) compression
Headers are dynatech headers 1 3/4 headers
Cam is 238/247. @.50
.637/.629 @.50
Lobe sep 112 degrees +4 adv
Just looking to understand how I get a general idea of what pulley (crank and blower) will be me around what boost
If that makes sense
.637/.629 @.50
If that makes sense
The math far the procharger is this...
Crank pulley size / Blower pulley * Internal step up ratio * Engine RPM's = blower speed
The Internal step up ratio for the F1A is 5.4 and the max blower RPM is 74,000. I don't know F1 pulley sizes so hopefully Bob will chime back in but here is my D1SC math for an example for you.
7.25''(crank pulley) / 3.7" (Blower pulley) * 4.1 (internal step up ratio) * 6,500 (engine RPM) = 52,219 Blower RPM's
This makes 9#'s of boost on my 383ci and I still have 10,000 blower RPM's left in the D1 before I hit it's max.
So now you can change pulley sizes to get your desired power level. I would get a recommendation from Bob on a good starting point and pulley it from there.
Your not going to get a boost # from any equation. The boost # really doesn't mean anything anyway.
I had the same pulley combo on my 347ci motor and would see 11#'s. Now with the extra 36ci the boost is reading 9#'s but makes more power. (nothing else in my combo changed)
Boost #'s are a measurement of restriction, take your engine for example... The 1-3/4" headers are a choking point on that big of a engine. So say you make 10#'s of boost with X pulley combo. Throw a set 2'' headers on it and dont change any thing else you will see your boost # drop and power go up. Hope this makes sense.
Your not going to get a boost # from any equation. The boost # really doesn't mean anything anyway. I had the same pulley combo on my 347ci motor and would see 11#'s. Now with the extra 36ci the boost is reading 9#'s but makes more power. (nothing else in my combo changed) Boost #'s are a measurement of restriction, take your engine for example... The 1-3/4" headers are a choking point on that big of a engine. So say you make 10#'s of boost with X pulley combo. Throw a set 2'' headers on it and dont change any thing else you will see your boost # drop and power go up. Hope this makes sense.
The motor NA now with 9:1 compression runs 432 rwhp.
I go above that 800 number and I start risking the rear etc.
This is an M6 car as well
LS1Tech Sponsor
I'd go with a 4.25 blower pulley, which should get you in the range you're looking for. Bob
__________________
he meant SPRAG... not "Sprang"
http://www.atiracing.com/superpulley/
dont know where you got that # on the ATI Sprag... but you are WAY off...
the ATI Sprag is a 45 tooth and supports up to a 70mm wide belt(pulley is actually 75mm wide).....and its an 8mm HTD Belt (8mm from center of one tooth to center of the next tooth
45 teeth *8mm = 360 mm Circumference or 114.6mm Diameter or roughly a 4.5" diameter
When doing a Cog Pulley, the same math applies as the formula listed above... Just do both Cog pulleys in Teeth (its way easier for the math to figure out blower RPM)
Example...my setup
81 tooth Crank Pulley
45 Tooth ATI Sprag Pulley
F1c = 5.4 Ratio
I will spin 7400 RPM ~ 7800 RPM
81 / 45 * 5.4 * 7400 = 71928 Blower RPM
or at 7800 = 75816
overspinning the F1 blower by a small amount is not an issue typically, but it will require more frequent rebuilds
Example...my setup
F1c = 5.4 Ratio
or at 7800 = 75816
