huron speed guys step in
What does your alternator look like now after moving to the top of the pass side head?
Pix and how much had to be cut.
I just cant put myself to cutting a brand new alternator covering smh
I dont have pictures, but I removed the entire plastic cover and spray bombed the whole thing in a black high temp paint. Looks pretty good to me! If I remember tonight, I can snap a pic for ya.
I did the same thing, tight to the fill neck but works fine.
Be careful removing the intake manifold if you have a metal one with a relocated alternator. Sparks will happen if you forget to disconnect the battery and having loose fuel rails with this makes for an exciting day.
