3.90 in stock 10 bolt
Thinking of throwing 3.90 gears in my stock 10 bolt. My car is an M6 01ws6 and pretty much stock except for air lid, adjustable panhard and lcas. It is a true daily driver but with a rotating 12 hr work schedule I only drive in traffic hours 5 times a month. My commute is probably 10 miles city/traffic lights and 15 miles hwy one way.
I was originally thinking 4.10s but thought 3.90s might be a little more durable and maybe i wont have to shift so quickly down low. Do you think its worth it or just a recipe for disaster? I dont really beat on the car since its my DD and commuter. I got 3 points on my license right now so I am trying my best not to drive too crazy lol. Im thinking with avoiding high rpm launches I'd be ok with the stock 10 bolt. Thoughts? Also was thinking of going with motive gears and the motive install kit. Anything else id need?
Ok that's what I was hoping to hear. Forgot to mention this car will see 0 track time. What all do I need. Just the ring and pinon set and ring and pinion installation kit? Anything else I'll need to pick up? Any thoughts on 4.10 vs 3.90s? Is it personal preference? Is there a noticeable difference? Will I be happier leaving a light with 4.10s?
Ive had both in stock 10 bolts. There is only a slight noticeable difference between them. Both are great but I defiantly like the 3:90's better. I noticed that I didnt have to shift "as" much with the 3:90s. Both make a 6 speed ALOT more fun to drive. On the highway you can still cruise at 80mph and only be around 2200rpm. They make 5th & 6 gear more useable.
Get the ring & pinion, a rebuild kit and some rearend gear oil.
AND don't forget to have your PCM recalibrated for the new gears. If you don't, your speedometer will read faster and you odometer will rack up more miles than you actually have on the car....And while your having the PCM recalibrated, have them move the rev limiter up to 6500.
yea I have a ton of traffic lights to deal with so having to shift less appeals to me. Does the rebuild kit have more parts than the instiallation kit? this is the one I was looking at http://www.summitracing.com/parts/mgr-r75grskt
I've come around to the opinion of don't put any money into the 10 bolt, BUT yours is a case of where it would be okay. I initially didn't care for all the shifting 4.10s vs 3.42s but now 3 years later I'd never go back to a 3.42 rear except if I sell the car. IMO the amount of shifting in normal driving is very similar to a Honda with a 5 spd. Skip shifting from say 3rd to 5th is no problem. With either gear set you can forget about hooking up in 1st gear and probably half of second.
only the shop doing the work can answer that question.
today I started teardown/cleaning/POR15 of a rearend.
for 6 years I ran the OEM 3.23 rearend,then put a 4.56 rearend in,and now 3 years of the OEM 3.23 rear (after a rebuild) back in. the 4.56 rearend is just sitting there crying to be put back in.
the rear I've started was a 3.42 torsen less axles and backing plates. axles and plates I had. don't know yet if I'm gonna use a Torsen or an Auburn and which gears,3.42,3.73,or 4.10.
any gear will work good with an A4 FOR THE INTENDED PURPOSE.
-4.56s-I ran for 4 years,good light-to-light streetfighter and good 1/8 miler,too much gear for the 1/4.
-4.10s'-max gear for the 1/4 with a stock redline engine.
-3.90s'-5% more torque to the tires than 3.73s'.
-3.73s'-general preferred performance ratio.
BUT a good custom stall convertor should ALWAYS be considered first before a gear mod.
seems to me,because you're inquiring about 3.90s' & 4.10s',you're after better acceleration performance. at least you got the 3.23s',which GM opted as a 'performance axle'. but they never offered a performance convertor. cars that went to SLP could get performance convertors but even those were not worth opting for as I think they were B&M 2400s'.
A Yank SS3600/SS4000 or similar from CircleD would really wake up those 3.23s' without changing your freeway mpg like 3.90s/4,10s' would.
gonna send you a PM.
