Tuning fuel on a progressive dry dirrect port.
Old 06-30-2014, 03:19 PM
Benwb's Avatar
Default Tuning fuel on a progressive dry dirrect port.
I'm planning on running a dry direct port progressively using a N2O leash. Now i know due to it pulsing the solenoids i would go ahead and pull the full amount of timing from the moment the kit kicks on, but when it comes to fuel would i go ahead and add in the necessary fuel for the full shot amount(225-300) or try to ramp in the fuel at the same rate as the nitrous's rate? Ignition is controlled by A MSD6010 and fuel is controlled by an MS1 box.
Old 06-30-2014, 04:47 PM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
You will need to ramp the fuel side too, otherwise the car will go rich.
-Garrett
Old 07-01-2014, 07:41 AM
Benwb's Avatar
Awesome! Thank you so much, I guess the rest of the questions will just have to wait when it comes time to turn it once the motors in the car!
Old 07-01-2014, 10:04 PM
red fury's Avatar
Ask the GBR boys, shiznitty, atv racer.
Old 07-02-2014, 08:16 AM
ATVracr's Avatar
Are you trying to do this with the stock computer?
Old 07-04-2014, 06:00 PM
Benwb's Avatar
No I'm doing this using a megasquirt 1 box to control fuel and 6010box for ignition
Old 07-14-2014, 04:39 AM
tick creations's Avatar
-Garrett
I GOT A QUESTION ABOUT THE AFTERMARKET FUEL INJECTION SYSTEM CAN THESE SYSTEM BE TUNED TO USE NITROUS FOR EXAMPLE
(FAST) XFI 2.0™ EFI Kit • Big Block Chevy • Up to 1000hp
Edelbrock Pro-Flo XT EFI Systems for Chevy Edelbrock Pro-Flo XT Plus Upgrade
Old 07-14-2014, 08:32 AM
ATVracr's Avatar
Fast XFI can for sure.
Old 07-14-2014, 08:33 AM
ATVracr's Avatar
Never used that.
If it has tables in the menu to do that then it will work.
Pretty simple once you get a base and works really well.
Quick Reply: Tuning fuel on a progressive dry dirrect port.
