Opinions needed... 5.3 with a s480
I checked but none of these post are exact what i have i did search first
I got the billet wheel s480 t6 twin scroll... With a bugger turbo cam on a stock 5.3 how will spool time be would u think,?
2.5 hot side is probably to big. Run a 2.25 hot side. Get a custom cam spec'd that knows what your intentions are with the car and a loose stall that hits hard around 3800-4000.
Denmah, your buddy with the foxbody did that spool valve setup that was basically both sides merged into one half of the turbine housing, then a wastegate that went from the drivers side manifold over to the other half of the turbine. Was that worth the trouble you think or is it better to just stay divided?
