someone please help with throttle follower table
finaly got car to idle with nogos help on tunning cams
i have 227/227 .570/.570 112 lsa cam.
my problem is car doesnt return to idle in gear until a complete stop.
it stays around 1600 to 1800.
i have stock heads stock throttle body with hole in blade drilled to 7/32
stock maf long tubes borla 3.73 gears and 2800 stall. all cold start and hot start issues are taking care of thanks to nogos advise. just the damm throttle cracker or follower is agravating me some one please help with setting the parameters.
thanks for the help it will be much apreciated.
if you read more in nogo's idle thread, he mentions what to do when you have that "cruise" effect. I'd post up what it says except I don't have it in front of me right this second.
Take the car for a drive and check your idle. If the car goes on cruise control reduce the Idle Air in Gear Table .2 (further if necessary). If the idle holds at 2000 RPM for extended periods of time reduce the P/N Airflow Decay table for all points above 10 MPH by 5% (multiply by 95) until this stops. Be vary careful on this table.
