Exhaust.....merges, X's H's & chambers
I'm finally in the LS game after YEARS of yearning.
X-pipes seem to be all the rage now. But I remember back in the day it was h-pipes first, and around the same time the x-pipes came on the scene, a couple of my buddies were running "pro-chambers" (I believe by MAC) on their 2000+ mustangs. From what I remember they sounded pretty damn good....But I'm wondering why I don't see any general universal products that are similar in design? Never see anything similar for LS cars/trucks...what gives? Don't even see them for the newer Stang's either....!?!?
Hoping someone can shed some light on the pro-chamber or similar stuff. I was thinking it might add the sound I'm looking for on my LS2 CTS-V. Looking for a more pronounced exhaust note from my magnaflow exhaust (stock resonator). Stock cam/manifolds.
Not familiar with how Mac Pro Chambers were different than any other design. Where they a full case muffler.
X-pipe is superior to an H-pipe. They really got noticed when Sterling Marlin dominated Daytona in 1994. If memory serves he was the only car in the field running one, and he absolutely killed the field.
H-pipe keeps the majority of left bank/right bank exhaust gasses to their respective sides, allowing excess pressure to bleed across the H section. Low pressure on one side scavenges some high pressure from the other side. H-pipes have a smoother deeper tone.
X-pipes split all exhaust pulses at the X section, equalizing pressure on both sides and scavenging better than an h-pipe. This results in more power, especially at the high end. However, X-pipes have a raspy higher pitched tone, and the x-section causes harmonic resonance at certain RPM commonly perceived as "drone"
The Mac Prochamber is sort of a hybrid design. Exhaust pulses combine in the Prochamber and exit equalized. But it maintains a smoother deeper sound like an H-pipe and avoids the X-pipe rasp and resonance drone. I believe flow and power is somewhere between the two.
