1st time gear install help with gear pattern 9"
Old 07-06-2014, 02:24 PM
Uneverknow's Avatar
Default 1st time gear install help with gear pattern 9"
My backlash is .006 and the next click on my adjusters and it's at .010 backlash
Attached Thumbnails 1st time gear install help with gear pattern 9"-image.jpg
Old 07-06-2014, 02:26 PM
Uneverknow's Avatar
Don't know why it wouldn't let me load pics in same post
Old 07-06-2014, 02:34 PM
cyberkill's Avatar
I'm not exactly sure what I'm looking at. I've never used prussian blue, I can't tell if I'm supposed to read the shadows, or the really light stuff. You might need a stronger pattern. Either add some resistance (hold onto the yoke while spinning the axle) or run it through multiple revolutions.
Also, that's the coast side, what does the drive side look like?
Old 07-06-2014, 02:36 PM
cyberkill's Avatar
Oh..didn't see the 2nd post. The drive side looks pretty good, but I'm not sure if that's too toed in or not. The depth looks pretty spot on.
Old 07-06-2014, 03:25 PM
007FJ's Avatar
It looks good to me too. I'd like to see a little more than .006 though. There is a little sway in the retainer keepers if you cheat it a little on both sides. I think it might go a little more. That being said the, pattern looks god as is.
Richard
Old 07-06-2014, 03:39 PM
Uneverknow's Avatar
So what would you think is a little more then .006? Should I try to cheat it to .008? Or would .010 be ok?
Old 07-06-2014, 04:07 PM
Uneverknow's Avatar
So I'm at .008 now..
Old 07-06-2014, 04:10 PM
007FJ's Avatar
I'd try for the .008 but your pattern is good. I'd rather have to go back and tighten it up if needed than be on the bottom of the tight. I have done a lot of gear set ups for a non professional and have always had good luck leaning to the loose end rather than too tight.
I am not an expert nor do it everyday. More like one every 18 months or less.
I don't want you thinking I am some kind of Differential Doctor!
Old 07-06-2014, 04:13 PM
007FJ's Avatar
Typing at the same time. If it was mine, I'd try it right there.
Your pattern looks every bit as good as the one I finished today.
May we both have no Clunk nor Howl...Amen!
Old 07-06-2014, 04:39 PM
Uneverknow's Avatar
Talking
007fj thanks for the feed back. I am just looking for a little advice from someone that's done a few of these which you gave me. I thought my first pattern was good and also thought I should be at the .008 so you just confirmed my own opinion thanks!
Old 07-06-2014, 06:17 PM
01ssreda4's Avatar
I agree, its looks ok. I'd run it.
Old 07-06-2014, 11:00 PM
Uneverknow's Avatar
Thanks 01ss feeling better about it now hearing from a couple guys
Old 07-07-2014, 09:23 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
I would add .002 depth and run the backlash at .008-.010
Old 07-07-2014, 12:46 PM
Uneverknow's Avatar
When you say add depth you mean remove .002 for the shims?
Quick Reply: 1st time gear install help with gear pattern 9"
