Low vs high impedance injectors
Moderator
All of our cars use high impedance injectors, what you
need (impedance-wise) follows the PCM and what its
internal driver circutiry is set up for. Low Z injectors
need a peak/hold driver, not the simple switch-to-ground
outputs that we have.
You can get proper impedance injectors with more flow
than you need.
than you need.
