Unable To Separate 3-Piece Oil Pump Body On A 4T65E
Sorry for the noob nature of this question ... this is my first (and probably only) rebuild on a 4T65E. On this 3-piece oil pump that's inside this transmission, is there anything additional one needs to do to be able to separate the three plates that form the pump body? The pump has been removed from the transmission, but for the life of me I don't see why this thing won't come apart, aside from a small dowel pin running through it. Is this thing just frozen together, or am I missing something fundamental here? Any advice is much appreciated. Thanks.
Moderator
I know nuthin' about a 4T65E and I therefore called a local trans builder for you. He said you have to drive that dowel pin out as it indeed holds the pump together. He said it can be very tight, but you have to get it out.
Good luck.
Good luck.
Huge Thanks!
mrvedit, if you lived in my neck of the woods, I'd be glad to buy you a cold beverage of your choice. Thanks for the info.
Moderator
Your welcome.
BTW the info came from Haas Transmission in Dexter, Michigan; a family owned shop for 30+ years with a stellar reputation and friendly service. Its a shame that most people's local trans shops are not nearly as good.
Update
Again, many thanks! Maybe i can pay it forward to someone else sometime.
