LS1 Shop clean out
LS1 Shop clean out
Category: Accessories
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): IN
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
LS1 intake - $200 - SOLD
1993-2002 Fbody sub enclosure, loaded with 2 12'' legacy subs - $150
5.3 vortec intake (with fuel rail/injectors) - $100
1998-2002 Trans Am Honeycomb taillights - $250 - SOLD
1998-2002 Fbody ebony center console skeleton - $75
1998-2002 Trans Am ebony radio surround - $10 SOLD
1998-2002 Fbody front shocks (Monroe sense-trac, very low miles before I upgraded to bilsteins on my SS) - $60
1998-2002 Fbody ignition coils and harness (came off of 1998, so no brackets included) - $120
1993-2002 Camaro mirror (drivers side, needs repainted) - $10
5.3 vortec oil pan, windage tray, pick up tube, dipstick and tube - $75 SOLD
1993-1997 Fbody 6 speed trans crossmember - $25
1998-2002 Fbody clutch master cyl (GM stock, very low miles before upgrade to Tick on my SS) - $75
LS1 Cam position sensor - $15
Pro 5.0 shifter stick (stick only, no base) - $25
Pro 5.0 shifter stick (shortened, stick only, no base) - $25
2000-2002 Ebony trans am door panels (tyical cracks) - $70
1998 LS1 re-buildable engine - pulled running (had lifter tick) with over 225K miles, has sat disassembled for approximately 1 year. will need a hone, bearings, lifters at minimum. perimeter bolt heads included. New cam bearings included. No accessories, no intake, no oil pan. Pretty sure everything else is there. Cheap start to a performance build or LS swap for somebody...- $350 SOLD
