2000 Chevy Camaro Z28 403 LS2
Year: 2000
Make: Chevrolet
Model: Camaro
Price: $16000
Mileage: 114000
Private or Dealer Listing: Private Listing
Location (State): KS
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
316-670-4374
VIDEO CAN BE SEEN AT:
https://www.youtube.com/watch?v=QnhG...ature=youtu.be
After build with the old stage 2 clutch which was beat to hell, the car dyno'd rear-wheel at 481hp and 514tq on a dyno that reads 30% low, so the car makes about 625hp and 668tq to the wheels.
Engine, transmission, and rear-end have approximately 5,000 miles (with documentation)
Clutch has less than 100 miles and is still in the break-in period (very grabby)
Hurst SST short-shifter
SS ram-air hood
Custom paint
American Racing long-tube headers
Custom RM8020 Bell Housing assembly
403 LS2 built by Billy Briggs Racing Engines
BMR tubular transmission crossmember and torque arm
Upgraded control arms and tie rods.
Weld-in subframe connectors
C5 Z06 Corvette rims
Drilled and slotted brake rotors
Custom-built true-dual X-pipe exhaust
Strange 9" Dana-60 rearend
Moser axles
4.30 gear true posi
FAST 92mm "Big Mouth" throttle body
SLP Air lid.
AIR, EGR delete
FAST anodized red fuel rails
FAST custom ported 92mm intake manifold
4130 high-strength driveshaft
Stage-5 Spec Clutch
Lightweight chromemoly flywheel
Transmission rebuild and upgrade
Tubular panhard bar
36lb injectors
Tubular crossmember/lower control arm assembly
Alpine type R speakers
Kicker CVR 12" subwoofers
MTX 1001D Amplifier
Paint is 8/10 body is 9/10 and interior is 9/10.
Paint has a small scuff above front driver's fender, clear coat has tiny peel on hood scoop, leather seats are worn a bit.
