Questions about nitrous plate
So when I bought my car it came with a bbk 85mm throttle body. I noticed that I havent come across a plate this size.
My question is can I just mill out one of the smaller ones to match the throttle body? Or can I use a plate of a different size?
LS6 Intake. With a little more time on my hands I learned that the LS6 intake is 78mm. My throttle body is 85mm. I guess now I have to take off the TB and measure to see if the intake was port matched. But if it isnt. What kind of issue would I run into. Or does another plate work?
If it isn't port matched, I'd run the 78mm plate kit. You won't lose anything, and it's a lot nicer set up.
If it is port matched, I'd run a nozzle. Otherwise, you're wasting it being port matched.
Thanks for all the information guys. Ill measure the blade. Brandon Im really looking into using one of your guy's kits. Could I just mill out a 78mm plate to a 85mm? If you happen to know.
