>> 402ci stroker iron shortblock <<
Category: Racing Parts
Price: $2900
Location (State): TX
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
6.0L Iron block 4.000inch bore, old LS1 reluctor wheel
Eagle 4.000inch stroker crank(part#34640006100 in the first pic, but a little light)
Eagle 6.100inch h-beam rods
Ross XL400 pistons, dished and valve reliefs(guessing -15cc's)
ARP/Eagle Rod bolts
Not sure why they kept the stock main bolts, but I wasn't going to reuse them when I needed to run the motor. It's a good idea to plasti-gauge the bearing clearances when changing bolts since I didn't get the build sheet.
I can see some overspray on the bottom of the rods and in the lifter galleys, looks like they taped off the motor but not all of it when they painted it. I would put in a touch of re-crosshatching in the lifter bores.
It's got a used double roller timing sprocket on the crank, I'll take that off, because I don't have the cam sprocket. Not sure why they put a used timing chain sprocket on a new rotating assembly, maybe they were scraping together parts like I often do. Might be the same reason they re-used stock main bolts too.
It will need a little work wiping it all down, addressing the lifter bores, checking clearances when swapping to good main bolts/studs, so I'll put in a discount. Has the valley cover and rear cover.
$2900 cash and carry, no core needed, buyer pays for shipping and handling. No trades, I'm paring down on extra car parts.
Jay Johnson
north Dallas Texas
