347 n20 piston's. What's the best for 300 plus shot
Old 07-14-2014, 08:08 PM
98blueSScamaro's Avatar
Default 347 n20 piston's. What's the best for 300 plus shot
Hi I am in the middle of picking pistons for my 347 ls6. What would be the best piston for me? I will be at 12.2.1 compression ETP 215 heads with a 50 and 55 deg 5 angle valve job. Super Vic with a direct port system wet 4150 t/b h beam rods stock crank. Car should rpm well n/a but I want a piston that can take the heat if I choose to step up to a 300plus shot. Thank you for your time
Rob
Old 07-14-2014, 09:22 PM
GiggleJuiced_SS's Avatar
Any bigger named pistons like diamond or wiseco forged should b fine. Get a steel top ring and gap them according to nitrous recommended gap. I went with wiseco forged flat tops/steel ring and I would hit it with 300 all day long.
Old 07-14-2014, 10:41 PM
ZackMorris's Avatar
+1 on wiseco flat tops + upper steel rings
Old 07-14-2014, 10:44 PM
00SlvrSS's Avatar
I'm using diamond with ceramic coating and a steel top ring. Coating was just fire insurance. But yeah they handle it all.
Old 07-15-2014, 11:27 AM
RacerXLs1's Avatar
Are you guys hitting a full 300 out the gates or dual stage, sorry new to nitrous..
Old 07-15-2014, 12:13 PM
I will be spraying 300 out the hole and with a **** track it will be progessed in with a control like the launcher
Old 07-15-2014, 06:22 PM
RacerXLs1's Avatar
I'm assuming your talking about 41? Lol
Old 07-15-2014, 06:32 PM
41 is not that bad but gld now that's bad
Old 07-15-2014, 09:01 PM
ATwelveSec02Z28's Avatar
I'm a fan of diamond... Current pistons in my engine are coated top and skirt... I have a set of I coated spares.... I'll be tearing down at the end of the season (hopefully not sooner)
Just make sure you get the lowered top ring and the proper pin and alloy for heavy nitrous use
Also if you haven't gotten the progressive yet, strongly consider the lingenfelter NCC-002. By far the best controller out on the market
Old 07-15-2014, 09:12 PM
GIMPY02's Avatar
Ur crazy to say gld is worse than 41. I'd rather make passes on gravel before I'd go to 41.
Anyways u can't go wrong with either that have been mentioned. Like stated just make sure u get a steel top ring. Je is another one I would go with.
Old 07-16-2014, 05:50 PM
Oh I know they both blow just spreading the love. I like the JE and I been looking at arias. Looking like I should ago my rings around a low 30 the high 20's
Old 07-18-2014, 09:25 AM
StrokerTA's Avatar
Yea, GLD is bad.... We've been low 1.20 60's, with the fastest stock cube nitrous car, on a 28x10.5...
Also been .930 60's in our pro-mod cars...
Diamond FTW!
Old 07-18-2014, 05:35 PM
BAKED's Avatar
I have ran 300+ on Diamond's and Weiscos in my 347. Both 12.5:1 and both did just fine.
Old 07-18-2014, 11:04 PM
Now what will I use for timing retard with the bcc-002?
Old 07-18-2014, 11:07 PM
Diamond FTW!
Yeah I know 60 foots are not the problem just bumps in the track
Thank you for the info
Quick Reply: 347 n20 piston's. What's the best for 300 plus shot
