Torque converter
Torque converter
I have a 4l60 that I am about to use with my 5.3 in my monte carlo ss. I wanna change the fluid out or would a filter & fluid change be enough. Can u drain a torque converter and refill it. What transmission fluid would you recommend as the will be a daily driver.
No way to really drain a converter 100%, but turn it over in a bucket over night. Also good to check the fluid coming out of the converter for any debris. And a fresh trans filter like you mentioned. DEX 6 is suppose to take heat better, but most use DEX 3 and it works great.
Chris
Chris
