modified bosch motorsports injector from fic?
*****this thread is not the place to start another id vs fic vs other debate
if you want that do some searching you will find plenty of @#@# to read*****
so i ordered a set of fic 1000's (60mm tall ev6 plug)
i received a set of bosch motorsport 48mm extended tip injectors with a red lower spacer to make it 60mm and an ev1 plug
the tip of the injector shows tool marks from some modification
the tail end of the bosch part number is ground off but looking at several i can make it out to definitely be 0280158123 which pulls up to a bosch motorsports injector that flows ~600cc (stock) with all the same dimensions
i called fic and they were very professional and said they sent the wrong injectors but they were a more expensive injector ($92 ea) and i could either keep them and they would send me some ev6-ev1 adapters free or swap them out
they emailed me the data sheet (labeled fic 1000)
anybody have these? results?? ease of tuning??
