poly motor mount shell bolts
Old 07-21-2014, 11:19 AM
Gotit4cheap16's Avatar
Default poly motor mount shell bolts
I got a set of poly unrethane motor mounts from a friend vut I do not have the bolts. Does anybody know the bolt size and lenght that I could go to the nearest lowes or home depot and get to use for the clam shells?
Old 07-21-2014, 12:30 PM
conan's Avatar
I used 3/8" x 1'' long bolts with lock nuts.
https://camaroversion20.shutterfly.com/292
Old 07-21-2014, 02:24 PM
Thanks conan. I appreciate it.
Also how did you go about drilling the holes?
Old 07-21-2014, 02:32 PM
conan's Avatar
3/8" drill bit on the Dewalt, drilled out the OEM holes from the rivets to 3/8"
Old 07-21-2014, 03:26 PM
Cool thanks
Old 07-23-2014, 03:21 AM
GiggleJuiced_SS's Avatar
Exactly what I did for mine. Make sure you don't install them upside down. I did one at a time to make sure I did it right. I believe they also call for a torque spec on the bolts to hold the clam shells together but I forgot what it is. Oh and they are a tight fit til the are all bolted down.
Old 07-23-2014, 08:43 AM
That's MISTER MODERATOR
Paul Bell's Avatar
Make sure you get grade 8 bolts and nuts.
Quick Reply: poly motor mount shell bolts
