FS: Fuel Injectors- Saturated Injector SH4-0750 (set of 8)
Category: Engine - Intake/Fuel
Price: $350
Location (State): NC
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Note: C5 has higher fuel pressure than what the specs list, so per my tuner these would be about an 80 LB. injector on a C5.
RC Engineering is the world's leading supplier of made-to-order, high-performance, electronic fuel injectors. RC injectors are available for a wide range of automotive, motorcycle and marine engines used in high-performance or racing applications.
Flow Rate - CC's:
750 CC's / MIN @ 43.5 PSI
Flow Rate - LB's:
71 LBS / HR @ 43.5 PSI
Resistance:
12.5 Ohms @ 68 F
Voltage:
8-15 Volts, nominal 13.5 Volts
Amperage:
1.0 Amps
Pressure:
Min 30 PSIG / Max 70 PSIG
$350 shipped + 3% PP fee within 48, OBO.
thanks
