Engine surges at idle after WOT runs...otherwise ok
My engine surges at idle, but only after WOT runs. If I nurse it around for awhile, it's back to normal.
My feeling is that I need to either drill the TB more or add idle air slightly...any suggestions that will mke this quicker to dial in?
232/236 cam, Patriot heads, headers, stock maf and LS intake, shaner tb with .100 hole.
Moderator
Before any of that I would take a look at what
your engine coolant temp is. May just be way
overheated, stock program has fans not even
started until 224F stock and heads are hotter
than that; fan settings might fix it all?
