PRC .675" EHT Double Spring Kit, brand new! TRADES!?!?
Category: Accessories
Price: $275
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, Front wheel drive vehicles
Location (State): CO
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
(FROM TSP'S WEBSITE)
Precision Race Components .675" EHT Double Spring Kit
The all new PRC .675" spring kit uses a highly advanced EHT Chrome Silicon spring wire for incredible high RPM valvetrain stability. This Extra High Tensile Strength spring wire offers unmatched reliability and performance compared to competitors LSx valve springs. The EHT Chrome Silicon spring wire allows over 2.5 times the life of previous tested LS valve springs! By using the best possible materials & carefully tuning both the inner & outer springs frequencies, PRC has made a valve spring that is more stable at resisting harmful harmonics that can lead to failures.
This spring kit has been tested well past the recommended limits, we have successfully dyno-tested the EHT spring kit to well over 7,400 rpm at .708" of lift! The best part of this spring kit is it's priced at well over $200 cheaper than competitors spring kits that are designed to compete with it!
Kit includes: Spring Seats, Valve Seals, Dual Springs, and Titanium Retainers (utilizes GM factory valve stem locks, not included)
Specs:
Install Height: 1.810"
Closed Spring Pressure: 148lbs @ 1.810"
Open Spring Pressure: 450 lb. @ .600" lift
Open Spring Pressure: 490 lb. @ .675" lift
Maximum Spring Lift: .675"
Coil Bind 1.060"
Spring Rate: 483lbs/in
pics will be up soon, WILL ALSO TRADE OR DISCOUNT FOR DUAL .625/.650 SPRINGS, LS3 INTAKE VALVES, LS3 INJECTORS, 4 BOLT 90MM CABLE THROTTLE BODY, C5 OR C6 POWER STEERING PUMP, C5 OR C6 SERP BELT TENSIONER, LS1 E-FANS, 4K+ 4L60E STALL.....
