Converter won't stay locked while cruising
I have a 4l80e behind an LQ4 in a Foxbody mustang. Trans and converter (FTI 3500 stall) are both new. When cruising around on the freeway the converter will only lock up about 25% of the time. It will lock for about 30 seconds to a minute and then unlock for a few minutes. No big changes to throttle or anything, just normal cruising down the road. It doesn't seem to be an issue in lower gears when driving around time. Unless I just don't notice as much. Is there something in the tune possibly or a mechanical issue somewhere? I have HPtuners if there is something I can change.
Thanks, I will give it a try. Mine will generally drive about 10-30 miles from cold start at roughly 50-70mph. It will stay locked until I give it like 10%-30% throttle and it unlocks and act like its slipping. I kick it down a gear and it will lock again then no slip at 10% or so throttle and pull strong in od actually lugging the motor if I give it enough to accelerate but not downshift. All will be fine then maybe a couple of miles more it might do it again. I ahd the car dyno tuned with stock converter. I installed the ss3600 and it drove fine for about 5000-6000 miles until I noticed it. I am getting a random misfire code now. When it unlocks I can clear it using hp tuners going down the road and it instantly locks again. Hopefully adjusting the misfire table will fix it.
it will work. I never got a misfire code on mine, and never noticed these "misfires" it was detecting, but the PCM will pick them up regardless. Just desensitize the misfire settings (I believe I set it to allow for more misfires).
I only adjusted the low and maybe mid RPM tables, the high RPMS I didn't touch.
My theory is as the motor spins faster, it helps "center" everything like swinging a bag full of stuff fast enough that it doesn't fall out. Hence no issues at higher RPMs
I don't remember, I don't have my laptop with me.
but some cells only allow a couple hundred "misfires" before it affects driveability. Other cells have like over 1,000 counts before it causes issues.
I think I just upped the numbers of the "low" cells up to like 1,000 hits before it affect driveability.
