LS1 windage trays
LS1 windage trays
I just purchased a LS1 truck oil pan for a conversion, it has a built in baffle in the pan although I have seen other trcuk pans with windage trays.
Would there be any difference between the 2 performance wise? Does the windage tray make any difference?
What do corvettes/camaro's etc have windage or baffles?
Moderator
Originally Posted by GTS346
So if I use the truck pan in a car conversion can I get away with just the baffle or do I need the tray as well?
I would use both since that is the way truck engines are designed. Couldn't tell you if the truck and LS1 is the same, but I would expect they are. Obvoiusly the truck pick up tube is needed since it's longer.
