GN 3.8 turbo motor swap
Ok since i bew my motor and trans i fig i should do somthing on the differnt side i was going to turbo my lt1 and but now since i saw in gm high tech a formula with a GN 3.8 swap i think ill go along that rout any one know what i need or how easy it is any info on this would help alot, i was thinking i could use a firebird v6 5 speed 2 if that would bolt up to the GN motor Please it would be a big help if one of the f-body big time guys around here could give me some info 2 http://www.gmhightechperformance.co...09gmhtp_byebye/
could this be put up top 2
no its not the same, im sure you need new motor mounts, headers, custom turbo tubing, oil pan, hoses, crossmembers, driveshaft, fuel system, etc. im sure that stuff will add up to quite a bit.
