Huge LT1/LS1 parts lot... Boosted Forged everything must go
Category: Accessories
Price: $12345
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette
Location (State): WV
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4
LS Engine?: Fits LS Engine
The Shortblock: all together and assembled: $2000
-Scat 4340 Crank: $300
-Manley H Beam 5.7 forged Rods: $SOLD
-26cc Dish Malhe Forged Pistons: $350
-The block itself machined to a 383 with splayed caps: $SOLD
The Heads: Dart Pro 1 Competition series 200cc port volume 58cc chamber volume, Angle Plug, 2.02/1.60 Int/Exh Valves, Assembled 1.550D Springs. Fresh resurface and 5 angle valve job. Ported and polished with supporting flow data: $SOLD
The Management: EFI Connection 24x Coil on Plug ignition: $SOLD
-EFI Connection plug and play Harness for 97 Auto car with cam extension.
-Factory 97 Timing Cover
-EFI Connection Throttle body plate
-Single row Timing set with cam and crank reluctors and pickups
-You'll just need coils and an LS1 PCM (I'm keeping mine for the new project)
The Boost: Vortech V1 S-Trim Blower: $SOLD
-Fresh of a rebuild, never ran with this build
-3 pulleys, the standard, and two smaller ones (I can get sizes when i get home but i believe there 10 and 12lbs pulleys
-All supporting hardware and brackets for an LT1 or SBC
All the rest: All the misc. stuff
Jesel Shaft Mount 1.5 Roller Rocker setup: $800
Port matched to heads Lt1 Intake with EGR Delete with polished rails: $100
TPiS 58mm Dual Blade Throttle Body: $300
TPiS Long tube headers and Y-pipe (painted): $200
Canton Deep sump oil pan and with oil pump and pickup: $250
Chevy Performance high vol oil pump: $50
TCI Flexplate SFI approved: $SOLD
Yank 3800 Stall: $SOLD
4l60e Trans with upgrades (message for details): $250 local pickup
Powdercoated gunmetal LT1 smooth Valve covers $50
Comp standard length hardened pushrods: $SOLD
Modified 8an LT1 Fuel rails: $50
Stock Lt1 waterpump with powdercoated front cover: $50
Ill probably be adding to this list as well but this is the bulk. Id really like to move some of the bigger pieces before I start letting go of the little stuff but like I said, make me offers, im ready to be done with this thing. We can work out shipping details and arrangements. Feel free to pm me on here or email me at wiest.andrew@gmail.com. Pics available upon request.
