94 z28
94 z28
Hey guys just signed up.
I'm having overheating problems with my lt1 94 camaro. I've removed the radiator cap nd let it run on its own. The engine coolant is evaporating nd bubbling out. I've had the radiator flushed out nd bled the lines nd have had head work done so still not so sure what the problem is or what I'm doing wrong?
Hey. I'm new, too. Do you see the coolant circulating in the radiator? If not, it may be a water pump issue. Is the radiator fan turning on? Have you checked the thermostat to make sure it's opening when the temps get high?
