Planning to go standalone with my FAST, not sure about certain gauges...
LS1Tech Co-Founder
I am going to go full standalone with the FAST, but I am unsure if my coolant temp and oil pressure gauges will work in the dash afterwards, I have been told that they both do not go through the engine control harness, anyone know which ones do and which ones don't?
LS1Tech Co-Founder
You are just confirming what Whitt said Levi? I appreciate all the help I can get, I need to buy gauges so as not to get stuck next week after the conversion.
I know we can control the fans thru FAST, but I'm not sure about water temp.
LS1Tech Co-Founder
Brian, I am already running the partial FAST (fuel controlled, but timing controlled by LS1 Edit) as a piggyback, but I am running out of room under the cowl plus if I have to troubleshoot stuff anytime in in the future there are so many wires to check that it would take forever. I already have a non-working speedo since I did not do the stuff I needed to do for the T400 swap, and for some reason my fuel gauge does not work (CAS tank) so it's not like I'm going to be missing much now as it is. And I have a centrally mounted 5" Autometer tach in the car now.
