!AIR and new wires running very badly
Hi, thank you for checking out my post. I did lots of searching before i made this post, nothing i could find matched the problem.
I have a 98 LS1. Car has bolt ons and 228 cam. The car has run excellent the last year ive had it. Yesterday i was going to have a mechanic i work with install plugs, he pulled the drivers side, said they were in good condition and recommended not replacing them. So back in they went, i asked him to install the MSD wires i had purchased anyway, which he did. he also removed the AIR tubes and put the block off plates with gaskets on them as well as taking off the AIR pump itself.
I got in the car to drive it and its running like a dog, hesitating, no power. and when idling it will occasionally backfire. The cars "check gages" would flicker as well, Which it never did before.
The mechanic pulled the plugs out, checked for cracks in them, checked to make sure the wires were all on tight, OHM tested them. He thinks the reason the car is acting up is because of the AIR delete, i don't really know what to think at this point. Any help would be greatly appreciated!!
IMO, the only thing with the air delete that would cause any of those issues would be if the block off plates weren't sealing completely. Otherwise a issue with spark.
I'd also make sure that the MAP sensor or anything else behind the intake manifold didn't get disturbed.
I'll check the MAP sensor when I get back to work. I was under the impression that the 98-00 didn't have any other vacuum lines that needed to be blocked off. I'll check that as well. Thanks again for all comments!!
You can get rid of everything in these 2 pics. I outlined them in red.
[IMG][/IMG]
[IMG][/IMG]
On the T fitting in the back of the intake you have the hose facing the pass side of the car. That is for the HVAC trap door, you need to plumb it back in to the nipple the T fitting was on. So just get a straight rubber boot to plumb that line back on the intake.
What part of Utah are you in ? I'm up in Park City.
[IMG][/IMG]
[IMG][/IMG]
Sounds like a problem with spark to me.
The blinking check engine light means misfires are detected.
Put the stock wires back on and change them one at a time until it starts misfiring again. May have to do the same thing with the plugs. Probably a hairline crack in a plug that is hard to see.
Thank you everyone for the feedback!!
I went back to see if i could figure it out and the mechanic had said he pulled all the plugs off and didn't see a problem with them. Car NOW runs perfectly. Friend of mine who also works at the dealership said the kid ran to a parts store in between fixing my car. My guess is he cracked a plug and found it when he was checking the wires, ran to an Autozone and bought a new plug. Will not be having him work on the car again.
Conan, Im living in Orem. Park City is a beautiful place
