complete th400 swap for t56
Th375 which is a 400 with a smaller output shaft
had it built a few years ago
full manual no brake
3600 stall
custom steel drive shaft
quicksilver shifter
cooler lines are high pressure rubber lines, cooler included also
dont know what's in it, I dropped it off and told the man that I made 728 hp at the wheels and I needed it to hold that and a little more down the road.
a small peice of the bellhousing has been welded back on, this happened a few years back and has never caused a problem
Not looking to sell, want to trade for a t56 setup
I can add cash if needed
I'm located in Nashville tn and will drive to meet
3600 stall
quicksilver shifter
Can u send me pics of tranny ive got a complete set up with z06 clutch all was shifting good when pulled from my bone stock 98 ta when i did engine swap well beside pedals was going to synco it while its out but ive been thinking turbo drag car for this one so auto would fit the build. Was think a 80 tho. But 400 would do with a gear venders. Do u have crossmember and ring gear flex plate . U will need a flywheel. Its rusty and on engine so i could start it and u know im going to want some money with this trade or what other parts you got need turbo stuff and suspension stuff
