Very strange headlight issue
I'm fed up... One of my headlights was grinding so I got a new nylon gear and pulled the motor and replaced the gear. Put it back together and tried it out and...it started grinding again and ruined my new gear. Luckily I had another gear. Pulled the motor again and replaced the gear, but this time I tried the manual adjustment first, and this is the issue I ran into:
When I raise the headlight, it hits the bump stop. But when I lower it the arm is like an inch away from the bump stop. I'm guessing this is why the first new gear died. What the heck gives!?!? I hate these stupid headlights...
Please help, I've been fiddling with these headlights all day...
Bump.
Someone has to know what I'm doing wrong... Do I have manually move the light to a certain position before putting the fuse back in? Does the position of the other headlight have any effect?
B/G -
Look at the other / working headlight's two-piece armature - and then compare the working unit to the unit not working correctly; I think you'll find your issue if you compare and contrast the two sides.
Well, I finally figured out that the motor itself was a little loose. So I bent the metal tabs and then it was solid again. Reinstalled another new gear. Lights work now...finally...
