roller rockers, what's the best valve cover solution?
Old 08-17-2014, 12:38 PM
RADEoN's Avatar
Default roller rockers, what's the best valve cover solution?
So I'm in a mess. I'm working on putting these roller rockers on my engine. I tried fitting the valve covers on, and as usual with my life, I don't have clearance.
I drilled out the baffles for the valve covers, and still don't have the clearance. I'm looking at spacers, but realized that I may have ruined my current covers. I'm also looking at a set of new taller covers. The biggest problem is, I don't want to buy spacers and need new valve covers to retain my pcv system. I also don't want to buy custom valve covers and ruin them trying to put a pcv valve in them.
What route do I take here?
Old 08-17-2014, 07:11 PM
99Bluz28's Avatar
I hate to say it, but most of the taller valve covers, will require a coil relocation kit, and you still likely need to drill an mount fittings on then to have a functional PCV system. Expect to pay at least $260 on up just for valve covers. Then add roughly another $100-250 for a coil relocation kit if needed, and $10-$50 for fitting if needed for PCV system.
These are the hidden cost associated with many RR systems, especially adjustable RRs.
Old 08-18-2014, 05:56 PM
RADEoN's Avatar
so i'm better just getting the spacers?
Old 08-18-2014, 06:24 PM
forcd ind's Avatar
I got the UMI spacers, was a good solution, worked great
Old 08-19-2014, 10:01 AM
Nasty N8's Avatar
http://www.nastyperformance.com/shop/nasty-performance-ls1-billet-custom-valve-covers/
Every spacer we have dealt with has leaked. Can plumb any vent system you like into them.
Old 08-23-2014, 05:24 AM
Orange Juice's Avatar
Don't forget longer spark plug leads
Quick Reply: roller rockers, what's the best valve cover solution?
