Vibration...help!!
Old 08-20-2014, 10:10 AM
tmoney223's Avatar
Default Vibration...help!!
So I got a MWC 9" with 4.30 gears..broke it in and changed the fluids..drove it for about 300miles and now I get a bad vibration at all differnt speeds..most of the time it's past 55mph and it's not a little one either..seen that the jam nuts were loose on the tourqe arm so I made sure the pinion angle was set correctly again..still have the vibration..the U-joint nuts where loose so I tighten those up and still same thing...it does have a stage 4 t-56 but that's brand new...any ideas in what could be going on?..starting to irritate me and in trying to mess with the pinion angle and nothing seems to work..
Old 08-20-2014, 11:58 AM
LS1Tech Premium Sponsor
MidwestChassis's Avatar
You are sure that your pinion angle is correct? If so you also might want to check that your driveshaft is balanced properly and if it is check your tires also.
Old 08-20-2014, 12:35 PM
tmoney223's Avatar
I'll double check the pinion angle..would that actually cause the coming and going of the vibration at lower speeds?..if it's correct then I'll take the driveshaft to a shop to have them check the balance of it...thanks and I'll give an update after I do all that.
Old 08-20-2014, 12:38 PM
tmoney223's Avatar
Also just out of curiosity what weight of gear oil should I be using?
Old 08-22-2014, 11:08 AM
tmoney223's Avatar
So I checked pinion angle again and it's good put lock right on the U-joint bolts..and got it up to 60-70MpH in 4th gear and wasn't that bad put it in 5-6 and it's pretty bad..wheels are balanced as well..also I can feel in the trans tunnel from inside the car that it might be coming rearend of the trans..
Old 08-22-2014, 05:47 PM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
What driveshaft are you using? If it is the stock driveshaft with a conversion u joint, I have run into several cases where this combination has caused vibrations such as you're experiencing, because the driveshaft is one inch too short. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 08-22-2014, 05:49 PM
LS1Tech Sponsor
80/90w. Bob
__________________
Old 08-22-2014, 08:35 PM
tmoney223's Avatar
I've got the chrommoly 3" driveshaft..and thanks on the weight.
Old 08-22-2014, 08:59 PM
LS1Tech Sponsor
One inch longer than stock on the driveshaft length? Bob
__________________
Old 08-23-2014, 10:54 AM
tmoney223's Avatar
Correct. I got it with the rearend.
Old 08-23-2014, 12:22 PM
Blackhawk8's Avatar
I have the same problem. I installed a new S60 and MWC tonnel mount adjustable torque arm and new PST driveshaft and have had a vibration ever since. I've had the pinion angle from one extreme to another and the vibration stays the same, it starts at 90mph until about 100mph goes away and comes back at about 120mph.
Old 08-27-2014, 04:38 PM
tmoney223's Avatar
Yeah mine is all over the place still..adjusted it extremely one way and then the other..it seems it's better I between but will not go away..putting it on the dyno tomorrow to try and see where it's come in from..the next step will be to get the driveshaft balanced checked, if that doesn't work then the trans then the rearend..
Old 09-11-2014, 12:55 PM
tmoney223's Avatar
So come to find out my pilot bearing was ceased..hopefully the input shaft is ok and that's what the problem is..
Old 09-13-2014, 10:21 AM
frez777's Avatar
Pilot bearing was what? ceased? that's crazy, hope you got it fixed
Old 09-14-2014, 09:09 PM
LiT1_up's Avatar
Tremec has a great app that turns your smart phone into an angle finder. Get the app and follow the instructions, it help solve the issue I had with my 9". Get it for free at the google play store.
Old 09-20-2014, 12:12 PM
tmoney223's Avatar
The input shaft was still in spec. But 5/6 gear came off by hand but still good. Will need a new viper main shaft down the road...I used the angle finder on my phone and i like it...so I'm thinking from the input shaft moving around is what's causing the vibration..going to reinstall it with new pilot bearing and Aline the drive shaft again and hopefully it'll be gone.
Quick Reply: Vibration...help!!
