2000 Z28 lots of mods
2000 Z/28
The good
RPM stage4 transmision with a B&M shifter, Zo6 clutch and flywheel, ram slave cylender, and a new oem clutch master cylinder modified for hi-flow.
motor work includes a ls6 intake manifold, patriot ported stage2 ls2 heads. aftermarket cam ( not sure of specs), upgraded 85mm throttle body, slp smooth lid, under drive pully, pacesetter long tube headers and racetronics fuel pump, all tuned with hp tuners.
Wheels car has factory painted five spoke wheels with like new Micky Thompson e/t street and skinny street tires up front.dum
Also included are C5 Zo6 wheels (17&18s) (will need tires) also have 2 spare 17in C5 Zo6 wheels with Hoosier dot drag slicks ( 1 needs a plug)dum
Suspensiondum
lowered 2 1/2in with upgraded rear control arms and sway bar QA1 torque arm, drive shaft loop, DIY Subframe connectors, drilled and slotted rotors with hawk pads 4:10 gears mossier shafts Eaton posi, and an auto aluminum drive shaft
Car comes with factory Ws6 springs that have been powder coated red. car cover that has never been taken out of the box.
The bad
The car has 177000 on the body and is showing its age a little.dum
The interior is probably a 6/10 the drivers seat needs recovered.dum
Bad A/C compressor.
No radio.
The car should produce +-400hp to the rear wheels and make an 11sec pass with a good driver.
The good
Suspensiondum
The bad
Bad A/C compressor.
No radio.
