c5 tr6060 conversion fuel setup and misc parts
Category: Accessories
Price: $2147483647
Location (State): FL
Item Condition: Used
LS Engine?: Fits LS Engine
power steering pump with an lines to run a cooler mounted to the radiator $ 75
A/C compressor and bracket worked perfect when I removed it from the car $ 250 obo
Stock water pump with 180 t-stat and manual tensioner $130
RSI twin pump hanger with 2 pumps and all lines to run 2 -6 feeds (filtered) and a -6 return with regulator, I can give a detailed description how I ran all the lines $600
Canton over flow tank $100
C6 cradle with C6 tr6060 and c6 dif it is a full swap over remove your cradle and bolt this one in place. has less than 5k has an lines for front pump and cooler mounted for the diff, C6 axles a arms etc plus a set of Pfadt coil overs. I would like to sell with my TQ tube that has been modified for the front pump on the tr6060, tq tube has a 3.5 aluminum DS with billet couplers new bearings and new output shaft with a run out of .002. Handled 1100 hp with no issues has always had amsoil run though it and has been changed twice since I bought it.
$5500 for conversion with TQ tube. (EDIT) Willing to ship for 5900 with B&B bullets
