Delete P0751/P0757
Old 08-27-2014, 12:12 PM
TXZ28LS1's Avatar
Default Delete P0751/P0757
Is it good to delete these codes? I just installed my 4k stall, and i heard these codes should be deleted because it puts your car in limp mode.
Old 08-27-2014, 01:38 PM
LFSADRG's Avatar
Correct. Last week installed stall and right about 50 miles the SES appeared. Scanned and found code P0757. Researched and the codes need to be turned off so I did. Did another 50 miles and all is well.
Also might want to start tuning the trans as well. I used JimmyBlues trans table as a base and modified from there. Car shifts very well with majority of the settings.
File Type: pdf
Old 08-27-2014, 08:35 PM
TXZ28LS1's Avatar
Thanks... ill get those codes deleted. I just wanted to make sure.
Quick Reply: Delete P0751/P0757
