1994 Camaro cammed ls1/t56
Year: 1994
Make: Chevrolet
Model: Camaro
Price: $9500
Mileage: 55000
Private or Dealer Listing: Private Listing
Location (State): MI
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
1994 Camaro Z28 body swapped all parts from 1999 SS I used to own. Complete powertrain, suspension, and full interior swapped in 4 years ago. Clean titled.
Car is very dependable, would drive any distance without thinking about it. I am fully trained Master ASE certified technician working at a dealership. Overall great condition paint has blemishes.
55k on engine, trans, all suspenion components, interior, all modules and electrical components.
LS1 5.7
T56 trans
Texas Speed Magic Stick v.3 111 LSA
92mm FAST intake
92mm PTM Throttle Body
Double Spring PRC Platinum Springs
TSP Hardend Pushrods
TSP Ported LS6 Oil Pump
Racetronix LS1/LS6 36 lb./hr. Fuel Injectors
Scorpion Aluminum Roller Rockers
MSD Plug Wires
NGK Spark Plugs
LS2 timing chain
Long tube headers (fresh ceramic coating this spring)
Full texas speed true dual rumbler set up. high polish
LS7 clutch
LS2 flywheel
4.11 motive gear
boxed LCAs
Mechman low rpm alternator
UMI relocation trans crossmember
Weld in sub frame connectors
Line Lock
Nitto NT05R rears
Nitto NT05 fronts
Dyno tested @418hp to rear wheels
Cam and most add ons done at 52k
All brakes, full exhaust, tires, and alternator done this spring 500 miles ago
Likey forgeting some things. Will update
Have to see and hear in person to appreicate
Walk around video:
$9,500 obo
text/call
http://detroit.craigslist.org/mcb/cto/4638821209.html
55,xxx on engine trans rear axle suspension interior all modules ect... 100k on body only. Zero rust on body. Front clip repainted in 2011 at dealership only due to faded clear coat. Clean MI 94 Z28 title.
