Tt 4.8 11.16 @ 130
Tt 4.8 11.16 @ 130
I have a APS twin turbo 4.8 with a Powerglide. On 8/22/14 it went a 11.16 @130.49 mph. The short time was 1.85. The car is heavy, the glide is steep, and the 4.8 doesn't make great torque on the bottom. This was done with the stock 10 bolt, on 295 55 15 R Mickey Thompson Drap radials set at 16 lbs. Car has competely stock suspension, and is lowered with LCR brackets.
The car weighs close to 4000 lbs with me in it (I weight 260) and has zero weight reduction done to it. Full stereo with two 10 inch subs, full interior, you get the point.
This set up is currently out of the car and sold. Stepping up to a 6.0, PT76, A2W intercooler, and I am going to put the car on a slight diet. I should probably as well. Plans are to cage it, and to completely skip the tens and head into the 9's.....on a stock 10 bolt. Wish me luck.
