rear gear swap?
Old 08-30-2014, 09:55 AM
rjmarazzi's Avatar
Default rear gear swap?
I have a 1993 z28 with 3.23 rear gear I have put a vig 3600 stall in the car and want 3.73 gears. My question is is it going to be worth the time or money if my axle tubes are leaking. The mods on the motor are unknown except full bolt-ons and full deletes with a tune which is also unknown. I also know that when I did a head gasket change it has dished pistons. But the trans I blew up the planitary and now have a built trans with a good positive shift. I just don't know if it would be even worth it to put any money in the stock rear if it is leaking at the tubes. So what are my options?
Old 08-30-2014, 10:08 AM
rjmarazzi's Avatar
Here is a pic both sides look like this.
Old 08-30-2014, 10:11 AM
01ssreda4's Avatar
Thats not much of a leak. You could always have someone weld a bead around the tube to seal it up. A muffler shop would probably do it for cheap.
Old 08-30-2014, 11:05 AM
rjmarazzi's Avatar
What is a good brand to use?
Quick Reply: rear gear swap?
