Notices
ported 243 heads
Old 09-02-2014, 09:48 PM
dezlfrek's Avatar
Default ported 243 heads
torched a valve in my ported heads so looking for another set.. let me know what you have..
thanks
Old 09-04-2014, 02:57 PM
McCoyMotorsports's Avatar
On your next set have the combustion chambers and face of the valves ceramic coated.
That's what's being done to my 243's right now, along with a port job.
If these are of interest pm me an offer as I'm undecided whether I should use the 317's I'm having the same work done to or use the ported/ceramic coated 243's.
Old 09-04-2014, 09:28 PM
dezlfrek's Avatar
I am going with Inconel ex valves this time.. possibly ti
Old 09-04-2014, 09:45 PM
redgto4u's Avatar
How did that happen?
Old 09-04-2014, 10:55 PM
dezlfrek's Avatar
this is my second valve to go away.. the first was a stock 243 ex valve, car had a fuel pressure issue and went lean.
these heads shouldn't have had an issue. afr was 10.8 to 11 on the run before I checked.. these were manley stainless valves.. it seems from all the reading I have done that for extreme use such as I am doing racing constantly that people are running either Inconel or ti ex valves.. Im replacing the seat in this head and installing Inconel ex valves.. these will take a higher egt of which at this point I can only assume is the demise of the lesser ex valves..
Old 09-25-2014, 08:45 PM
j88l98irocz's Avatar
I have a set
Quick Reply: ported 243 heads
