windshield washer motor or button?
i press the button on the steering wheel, 2001 fbird, and it does nothing, the windshield wipers work just no fluid coming out, can't hear even if it is trying or the button just doesnt work, any way to check which i need to fix?
just buy the washer pump it's like 16 bucks at Advance Auto and takes a few minutes to swap out (unless you have large hands), its the cheaper of the 2 parts and the easier of the 2 parts, you could pull it and test it by putting power straight to it from the battery for just a second to confirm.
anyone have a how to on changing that? maybe going to a junkyard to find the part
edit* when i disconnected it i blew through the hose to see if it was stuck and it pushed through, so at least some hole is open on the other end.
Save the manuals!
The wires for this are in a connector at the base of the steering column, where the wires running down the column plug in to the car. This might be a good place to test the circuit. (you could apply 12V at the right wares in the connector) If the wires work from that point and you confirm the switch is bad in the column, you could tap in easily at that connector.
