FS: 2008 Pontiac G8 GT 450 WHP (Houston)
Year: 2008
Make: Pontiac
Model: G8
Price: $24000
Mileage: 84300
Private or Dealer Listing: Private Listing
Location (State): TX
Color: Gray
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
I have all the paperwork also from 510 of the work completed on the motor.
Current miles: about 84,300
Miles on built motor: about 15,000
Built and tuned by 510 race engineering
Mustang Dyno numbers: 450 whp 404 wtq
Text or call for more details 281-413-2749.
http://houston.craigslist.org/cto/4646303475.html
Interior- Heated Leather Seats, Sunroof, and Atari Gauges
Mod list: Built and Tune by 510 Race Engineering
Engine:
Built Studded Bottom end 11:5:1 CR
Compstar H Beam Rods
Racetech Forged Popup Pistons
ACL Cam, Main, and Rod Bearings
GFX Piston Rings
Comp Cam Upgraded Rocker Arm Trunions
ARP Head Studs
LS7 Lifters
Viton Valve Seals
Comp Cam Push Rods, Springs with Titanium Retainers
Comp Double Roller Timing Set
Melling High Pressure Oil Pump
Ported Intake Manifold, Throttle Body, and Heads
MSD Spark Plug Wires
NGK Spark Plugs
229/236 .624″/615″ 112 LSA Comp Cam
160 Degree Thermostat
DOD Delete Kit
NEP Underdrive Pulley
OBX 1 7/8″ Long tube headers with 3″ X pipe
Vcm Intake
LS7 maf
Bilet Oil Catch Can
Drivetrain:
Camaro Trans Deep Pan with Wide Mouth Filter
Circle D 245mm 2C 3600 Stall
Exterior:
Carbon Fiber Wrapped Pillars and Door Handles
Smoke Wrapped Side Markers
Front bumper lights Plastic Dipped Front Grills
Blacked out window trim
C6 exhaust tips
red calipers
Wheels & Suspension:
Camaro Front Brembo Brakes
Race industries dark star Wheels
17 x 4.5 with M&H 185/55/17
17 x 9.5 with NT05R 275/40/17
Polyurethane Front Lower and Upper Control Arm Bushings
GXP Rear Struts
