Fbody oil pan 125$
Fbody oil pan 125$
Category: Accessories
Price: $125
Part Fits: 93-02 Chevrolet Camaro
Location (State): NJ
Item Condition: Brand New
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Threaded area where drain bolt goes is damaged and will be required to be drilled and have a new drain bolt insert installed. Which will be supplied.
The pan itself did not leak. Originally I was going to repair it myself but I do now want to be held accountable for anything down the road so I will be supplying the insert (no pictures since I am still waiting for it to come in at the dealer)
A new OEM GM pan will run you 350$.
you are getting
you will need
(black **** around hole is tacky adheasive I had holding a drain bolt there while I was removing)
