Tuning question after injector swap..
Old 05-23-2004, 04:39 AM
Z28Venom's Avatar
Default Tuning question after injector swap..
I just need to make a quick adjustment to stop some smoking. I recently swapped from 26lb injectors to 28.8lb injectors.
The initial solution was to multiply the entire injector fuel rate table by 108.. It seemed to solve the problem, but I noticed that the car was still smoking a bit today when I was tryin to make a vid.
What do I need to tweak to fix this?
Thanks
(LS1Edit)
