2002 camaro SS low fuel pressure
I have a 2002 SS Camaro with 120,000 miles. I have low fuel pressure. I have 20 pounds on the fuel rail. Car was running fine, then started sputtering for a mile or so, and then died. Tries to re start but dies immediatly. Im going to start with the fuel filter replacement. Im thinking that is probably not the issue. Any one have suggestions on where to go next? I have the factory shop manual set, but the manuals seem overwhelming.
Does it sound like a plugged fuel filter or a relay or fuel pump?
Thank you for your replies.
Does the 2002 have a regulator on the rail or was that discontinued by then? If so, try that for sure. If not, definitely filter first. Relays are cheap and easy to replace so go there next IMO. Then fuel pump and check valve. Less likely but could be a leaking injector bleeding off pressure but it's probably not enough to keep it from running.
