Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
F body part out list
Old 09-11-2014, 09:44 AM
Mean87SS's Avatar
Default F body part out list
Category: Racing Parts
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): NJ
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
So, I am in the process of changing platforms... that means, all the stuff needs to go. Text me at 732.535.2162 for a quicker reply.
LARGE ITEMS I WILL NOT SHIP Located in 08837, central NJ.
All parts are for a 98-02 Camaro/Fbody or LSX platform if not a specific part.
Moser 9" rear, 3.70 gear, 35 spline axles, spool, welded backbrace, wolfe dragbar, 1/2" extended studs, comes with LS style backing plates with LS rear calipers that are ground down to fit weld wheels, with brake lines. $2200
TH400 built by Transmission specialties, RMVB, trans brake, rated to 850 HP, large sprag, new clutches, rollerized output, deep pan, new never installed Included is 20 quarts of type F trans fluid. $1400
3" alum drive shaft with 1350 u-joint made for a TH400/9" rear. $250
Edelbrock Vic Jr. intake for L92/LS3 style heads, powdercoated gloss silver(looks chrome) $325
Edelbrock medium profile elbow painted gloss black/clear coated(Infiniti Black obsidian) $115
Comp 224/224 588/588* 114 LSA cam about 6,000 miles $275
Borla adjustable catback has been run and removed, nothing cut, no plates $450
Camaro rear hatch thats gutted, gets pinned closed, Percys lexan rear glass, comes with pins and mounts, painted Artic white, no spoiler. Will accept a SS or Z28 spoiler no problem. $400
Wolfe bolt in 6 point bar, mild steel powdercoated black. Never tested. Rear bars go through speaker grills(have cut speaker grills to fit bars) $600
99-02 Camaro cluster with a Macewean white faced overlay 82XXX miles $100
Nitrous outlet dedicated fuel system for fuse area,
Quote:
Nitrous Outlet's dedicated fuel systems come complete with a custom built plastic 1 gallon fuel cell, mounting brackets, Walbro in tank fuel pump, Aeromotive fuel regulator, Aeroquip 6 An hose, fuel lines, and fittings.
New never installed or had fuel in it $500
Nitrous outlet stinger plate conversion with jets, braided lines, noid brackets, new never opened $370
Aeroforce scan gauges, pair of red guages, with black faced dials. $290
Pair of front 2000 Z28 camaro cloth seats, no rips or no seat tracks $40
QA1 front coilovers with 275# springs, Q1A rear shocks, single ajdu $550 for the set of 4
4" cowl hood for Camaro, I think its a Harwood, bolt on style, Still in black gelcoat. Slight cracking on the gelcoat but this never bothered me as I was going to paint it. Prior owner said the nut came loose on the hinge and had to add new. $550
TH400 crossmember from UMI for a conversion swap. $125
PTC built converter for a TH400 to a LS style motor. ~4200 RPM stall, new never ran $500
Racestar 'dark stars' 15x3.5/15x10 with proper Fbody backspacing. Mounted are 165/85/15 Nankand radial fronts, rears are 275/60R15 ET street pros, wheels & tires have only about 50 miles on them, mint no damages at all. $1100
Some parts like the cage and rear are still installed in the car and I can pull it out as soon as possible.
I have some STL beacons, strobe lights. They are very bright and are good for snowplowing/security. I have 3 Amber, 1 white. One of the amber lights have been opened and used this winter. $35 each.
Old 09-13-2014, 07:10 PM
Mean87SS's Avatar
Bump.
Old 09-28-2014, 10:40 AM
Firehawk441's Avatar
4150 or 4500 Flange?
Which solenoid bracket?
Old 09-29-2014, 03:30 PM
patrioticnova's Avatar
PM Sent
Old 10-06-2014, 08:07 AM
Mean87SS's Avatar
Stinger plate kit sold.
Old 10-06-2014, 08:46 AM
recliner15's Avatar
interested in the 224 cam please send me a PM
im local
Old 10-23-2014, 05:32 PM
Mean87SS's Avatar
Racestars sold. Stinger plate sold.
text me 732.535.2162
Old 10-23-2014, 05:59 PM
Randolph Ziskey's Avatar
Pm sent
Old 10-28-2014, 01:30 PM
imma_stocker's Avatar
You might want to double check that hood, I think Harwood only makes a 2.5" cowl for our cars.
Old 10-30-2014, 09:40 AM
kainedogg's Avatar
Still have the regulator?
Old 10-30-2014, 02:46 PM
Mean87SS's Avatar
What regulator??
Old 11-04-2014, 07:42 PM
Bama99z's Avatar
Default Parts
Sent you a P.M.
Old 11-05-2014, 08:09 PM
BC178's Avatar
Interested in rear but live in WI, to bad i guess. Glws
Old 11-09-2014, 10:03 AM
WS6tx's Avatar
Pm Sent
Old 11-09-2014, 02:38 PM
JCS94's Avatar
Hey man, willing to sell accessory drive system for f body?
Old 11-09-2014, 07:30 PM
Mean87SS's Avatar
I don't have one available.
Old 11-27-2014, 01:57 AM
frdassn5's Avatar
Do you have backing plates for a 99 transam 10 bolt 3 channel ? If so hit me up 5042758713
Old 11-27-2014, 08:55 AM
ss performance's Avatar
Which torque arm is the Moser 9 inch built for? Stock style or something special?
Quick Reply: F body part out list
