Gears & Axles - 4:10s or 4:11s
View Full Version : 4:10s or 4:11s
BADFNZ-383
05-23-2004, 02:57 PM
what exactly is the difference. and which would you all suggest. i will be getting my moser 12 bolt soon, and i just want to decide which gears. thanks
SidewayzOZ
05-23-2004, 03:04 PM
I was under the assumption that 4.10's go on 10 bolts/12 bolts and 4.11's go on 8.8/9 inch rears. Same gear basically, just fit different rear ends. Somebody correct me if Im wrong.
trackbird
05-23-2004, 04:29 PM
A 4.10 takes 4.1 turns of the pinion to move the ring gear one complete turn. The 4.11 takes 4 and 11 hundredths of a turn of the pinion to rotate the ring gear one complete turn. Meaning, virtually no difference (none that you'll ever notice). It is just a difference of ratios between the 10 bolt and 9". If you want one or the other, find what fits your rear axle and run it. You'll never know any difference, they are (in operation) identical.
mcflyz28
05-23-2004, 05:44 PM
Number of teeth on the ring and pinion gear.
Cal
05-23-2004, 11:59 PM
Both the 9 inch and GM 12 bolt use 4.11's, 4.10's are for the GM 10 bolt. As stated above, a different combination of teeth on the ring and pinion are used to get essentialy the same ratio.
kgkern01
05-24-2004, 02:02 PM
4.10's = 41 teeth on ring gear, 10 on pinion
4.11's = 37 teeth on ring gear, 9 on pinion
OWENMUSTANG
05-24-2004, 02:35 PM
Ford 8.8 =4.10
BADFNZ-383
05-24-2004, 04:10 PM
thanks for the info everyone
SidewayzOZ
05-26-2004, 01:19 AM
Ford 8.8 =4.10
ty ;)
