overthinking this solution
Old 09-11-2014, 02:24 PM
sleepy00's Avatar
Default overthinking this solution
Started installing my bottle heater with a relay in the back. Question is where can I get a good ground from. I was thinking bout scrapping down a small down to the bare metal where the nut holds the side marker light on. That's the spot my relay will be mounted to.
Old 09-11-2014, 02:38 PM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
You could ground it anywhere really. Just make sure its bare metal. That location should be fine.
-Garrett
Old 09-11-2014, 02:42 PM
sleepy00's Avatar
Thanks once again. Hot damn Garrett da man. If I ever see you in person, I owe you a beer or oil change...ha. Thanks bro
Old 09-11-2014, 02:49 PM
No problem man. Let me know if you have any other questions along the way!
-Garrett
Quick Reply: overthinking this solution
