stalling on long drives?
Old 09-14-2014, 09:27 PM
00silverGTP's Avatar
Default stalling on long drives?
Have a walbro 255. Car started losing power and eventually died after about 2hrs of driving. Let it sit for about and hr and it was fine. Did the same thing on the way home from my trip. Only thing I can think of is the fuel pump??
Old 09-14-2014, 11:41 PM
Mercier's Avatar
Could be the relays and/or wiring heating up so worth a check there. I had this same issue in the Jeep. Replaced the regulator and it got a little better but in the end was the pump. Relays are a lot easier to replace and good maintenance anyway so throw $25 or so at that first, IMO. Also clogged filter makes the pump work harder in theory so this should always be changed.
Good luck.
Old 09-15-2014, 08:24 PM
S10xGN's Avatar
Bet your tank isn't vented correctly. Next time it happens, pop the filler cap and see if it'll run...
Old 09-15-2014, 08:34 PM
interesting, never thought of that. haha.
Problem is I don't plan on testing it. its only happened 3 times in 6 years. lol.
Old 09-15-2014, 08:39 PM
S10xGN's Avatar
Well, I guess you'll stumble across a fix eventually...
Old 09-15-2014, 10:59 PM
Mercier's Avatar
Well just sell the car in the next two years and problem solved right?
Old 09-16-2014, 11:19 AM
thunderstruck507's Avatar
I agree, sounds like an issue with tank venting
Old 09-20-2014, 09:31 AM
so, why wouldn't it vent properly? or what I can do to make sure its vented?
Old 09-20-2014, 07:28 PM
S10xGN's Avatar
Most likely has to do with the evap emissions stuff. First, find a flow diagram, next isolate and bypass the evap canister, then "loop check" all the hoses to see if they're plugged.
Quick Reply: stalling on long drives?
