1998 trans am 43k miles built 6.0
Year: 1998
Make: Pontiac
Model: Trans Am
Price: $9500
Mileage: 43000
Private or Dealer Listing: Private Listing
Location (State): FL
Color: Black
Transmission: Automatic
LS Engine?: Car has LS engine
Contact: 850-293-2358
UPDATED 2/14/15 WITH NEW PHOTOS AND VIDEO.
I have a 1998 Trans Am with 43k original miles on it. It has a built LQ4 6.0 iron block motor has only about 4K miles on. Car sounds awesome and drives great, I would estimate 410-430whp and 450wtq. Car drives and shifts smoothly. Garage kept. Great price for a hell of a car. Could easily be a daily driver or a weekend toy. Interior is tan leather and interior is flawless outside of a small crack on diver seat that you can see in the photos if you look hard enough. Outside of that the interior is perfect. Exterior wise the car is in real good shape for a 98, no dents at all. Only exterior flaw is a crack in the clear coat on the front bumper where my girlfriend tapped the dang garage wall. There is a photo of it in the add. Could be fixed for couple hundred bucks if you like things perfect but I have yet to get it done. Only mechanical issue is the driver side headlight sometimes takes a minute to pop up due the the plastic gear worn, $50 fix. Car motor is in perfect mechanical and flawless shape. Im looking to buy a house and need to sell. Asking $9,500. The car is a blast to drive and has room for more power if your looking to build more. If not its got plenty of power now to have fun with and the engine build is a very reliable build. Underneath the car is even spotless for the most part. Feel free to text me at 850-293-two358. T-tops are in good shape also.
Engine Mods....
LQ4 6.0
Chrome moly piston rings
LS2 timing chain
LS6 oil pump
Katech rod bolts on the later model dimple rods
LS6 cam (02 up model)
317 heads w/ 5 angle valve job
LS6 springs, retainers, keepers
ARP head studs
CV .080 chrome moly pushrods
LS6 intaked
FAST fuel rails
1 3/4 headers
3" exhaust
Racetronix 255 pump w/ ground kit
Transmission mods.....
4L60Edum
5 pinion planetaries
hardened input & tail shafts
HD thicker sunshell
HD sprag
Trans Go shift kit
Billet servo
3200 Precision Vigilante stall
HD transmission cooler
Stock 10 bolt rear end with a few mods
VIDEO LINK BELLOW
VIDEO LINK ABOVE ^^^
I can try to get a video tonight. Dyno sheet says 400whp and 450wtq and the tune has been slightly adjusted since then for a little more power so id something around 415whp. Car runs and drives great. Just looking to sell cause I dont drive it much and I have a kid now and looking to get a duramax.
PM's responded too.....bump.....Not interested in any trades unless its a lifted 2008+ Duramax crew cab loaded interior in good shape, lifted 6+ inches with 12 inch wide wheels and a nice offset. Obviously I would throw in cash as well....
